koni ruined??
Old Oct 11, 2009 | 12:50 AM
Midnite_LS1's Avatar
Default koni ruined??
well i installed a 1in. rear sway bar on my car this past spring...i dont drive the car much, about 2k miles this year at most and all looked fine until now! i just noticed that the bar has been rubbing against my koni's...long story short, i now have one leaky rear shock...it leaks out a pin-tip size hole on the weld at the bottom of the shock. do you guys think this shock is re-buildable or not since the housing has been ruined?? i'd hate to have to buy new rear shocks......
Old Oct 11, 2009 | 01:53 PM
CranMaro99's Avatar
It's shot. There isn't a legit or safe band-aid for something like that.
Old Oct 11, 2009 | 03:25 PM
35th SS's Avatar
who makes the swaybar?if its a spohn replace it with a different brand.samething happening on my blk one.
Old Oct 12, 2009 | 10:15 AM
Sam Strano's Avatar
LS1TECH Sponsor
Shock is junk (and the other one might be too). You can't fix it, the body is trashed. And I'll lay money it's a Spohn bar.... Not only are they too tight to clear larger body shocks like Koni (vs. stock Z28 deCarbon's), but a 1" is too big anyway for handling (assuming you might like that since you have Koni's).
FWIW, Koni's are in stock... so are rear swaybars that won't hit your new shocks.
__________________
