Problem Installing Brakes...HELP!
First problem:
On my passenger front, I mount the rotor, caliper bracket and pads with no problem, but when i try to mount the caliper it doesnt sit right. Its almost as if one of the pistons isnt in all the way (but I asure you it is!). The mounting holes will not sit properly if the rotor is straight on. If I "make" the caliper fit inline with the mounting holes then the rotor wants to push out on one end about half an inch. Thought it might have been a warped rotor but I already swapped that. The original pads did wear uneven (like this: //).
Second problem:
On the driver side front, everything mounted no problem but now im noticing that the top bolt on the caliper itself goes in and out slightly, even though its tightened all the way.
Third problem:
I cant break the rear caliper bracket bolts for nothing!! Ive tried PB Blaster but they wont give at all.
Any suggestions? I am ready to drive her off a cliff at this point!!!
If pictures are needed let me know. Thanks!
Did you get the caliper bracket mounted?
Also push the piston fully in.
2 the reason it is moving is because its a free floating caliper. Dont worry about it. Once you press down the brakes that space will be taken up and you will have no more movement.
3 they went on, they will come off. torch them a bit if you have one. dont get them too hot though.
First problem:
Second problem:
Third problem:
Next check the caliper mounting bracket. Are the bolts straight and tight?? Not cross threaded??
Also, what brand of pads are you using?? Sometimes they are incorrect for the application, this is especially true with cheaper auto parts store brands.
Post pictures up if you can, we could better help you figure it out with a visual.
As fot the rear caliper bracket bolts, get the car as high up as you can and get a breaker bar under there. Should be able to get them loose with that if a regular ratchet won't do it.
