Brake Question Please Come In.
Also, always use a torque wrench to tighten the lugnuts. An impact wrench will cause uneven loading on the rotor which can also lead to runout issues (warping).
On a regular rotor, the best thing to do is get a dial indicator and check the runout of the rotor while it is still on the car but it is tougher with a cross drilled/slotted rotor. When I used to "cut" rotors years ago, I could put a rotor on a brake lathe and visually tell if a rotor was warped.
One last thing...you could just have a cheap rotor. I have seen new rotors with way to much runout out of the box which will get worse as you put miles on it.
Most Aftermarket Cross Drilled rotors could be directional by the brand. Check your suppliers website or give them a call to make sure you have them in the right direction. If your autoX or doing long trips might be why you have brake fade too.
