double caliper
Old Dec 8, 2003 | 08:10 PM
blueWS6's Avatar
Default double caliper
i was looking through a corvette and chevy trader and saw a C4 and it said double caliper. Is that possible and has anyone done this?
Old Dec 8, 2003 | 09:35 PM
wrencher's Avatar
wrencher
Sure it wasn't some newer aftermarket double piston caliper?
You can do anything but you have to have the master cylinder to displace the proper volume to actuate that much hydraulics.
Old Dec 8, 2003 | 09:52 PM
blueWS6's Avatar
thats exactly what i thought at first was the 2 piston caliper but if it was me i would have said 2 piston caliper and not double caliper. hmm... oh well
Old Dec 8, 2003 | 10:43 PM
felton316's Avatar
I've seen the C4 vettes using 2 calipers, not a 2 piston caliper, but 2 different calipers. Not sure what the advantage is, but it has been done.
Old Dec 9, 2003 | 07:16 PM
Louis's Avatar
It is a common European Touring car practice when the rules limit them.
Disadvantage is the rotor only gets 180* to cool in racing apps. as opposed to the 360* with one caliper.
Old Dec 10, 2003 | 08:17 AM
roy's Avatar
roy
Ibelive that was when rotor size was limited . But I think that has changed ,at least last year in the paddies I did'nt see any on the touring cars.
Also of interst did u know camros and stangs rantouring car in the middle 80's, did quite well until Bmw and audi complained andtherestrictions were so tight that it wasn't doable any more.
Old Dec 13, 2003 | 02:55 AM
teamsleep13's Avatar
Its really not worth it, one properly sized caliper could do it in less weight, add more cooling area and be simpler.
Its been done as experiemental in some racing classes, but if you look at brakes in most car racing, none have more than one caliper per rotor.
Hunter
