strange or qa1?
Old Nov 2, 2009 | 10:38 PM
kalebm22's Avatar
Restricted User
Default strange or qa1?
i am looking to upgrade my front suspension for maximum weight transfer. which shock in the single adjustable version is the best for throwing the weight up?
Old Nov 2, 2009 | 11:39 PM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I use Strange DA shocks on all 4 corners of my drag car and I pull 60 foot times around 1.17 - 1.19 sec. Needless to say, I recommend Strange shocks for your car.
BMR sells both brands, so give us a call when you are ready to order.
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old Nov 2, 2009 | 11:42 PM
35th SS's Avatar
afcos-if you have the $$.
strange- in between.
qa1-last.and they work.
Old Nov 3, 2009 | 05:47 AM
qwk93ta's Avatar
Which Strange struts and shocks would you suggest for a car that is still driven on the street, but I want a good drag racing set up?
Old Nov 3, 2009 | 06:54 AM
tillery's Avatar
Strange for the price and alot better than QA1s.
Old Nov 3, 2009 | 07:24 AM
BlackScreaminMachine's Avatar
Internet Mechanic
All of the shocks work, some need them other really don't and they can save some $$$ staying with a shock that suits the needs. If the check book is bottomless then always buy the best.
I like my QA1's quite fine and I can't wait to get the R series on the front and see what it does at the track.
Old Nov 3, 2009 | 08:30 AM
BMR Tech2's Avatar
The single adjustable Strange shocks would be the ones that i would recommend. They are the best shock for the money and hold up well for a street/strip car. We ahve very competitive prices on both the Strange and QA1 shock. Here is a link to our site. If you have any questions please give me a call.
http://www.bmrfabrication.com/F4.htm
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Nov 3, 2009 | 10:33 PM
kalebm22's Avatar
Restricted User
wat spring rate would you recomend on the front? the car will be about 3300 without me in it. and most of the weight reduction is in the front of the car.
Old Nov 5, 2009 | 08:58 AM
BMR Tech2's Avatar
If the car is going to be driven on the street i would go with the 325 lb springs. This is a good spring for a street strip car. If its a weekend warrior/strip car the 300 lb ones are a good choice. Let me know if you have any other questions.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old Nov 6, 2009 | 12:07 AM
kalebm22's Avatar
Restricted User
so the lighter the spring rate the better the weight transfer?
Old Nov 6, 2009 | 08:29 AM
BMR Tech2's Avatar
Your spring choice is going to be determined by the plans you have for your car. To light a spring will not support the front end weight correctly. To stiff a spring will make the cars ride to hard and make it feel bouncy. Spring rate for a drag car will be alot different than the spring rate for a corner carver. Let me know if you have any other questions.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old Nov 6, 2009 | 11:50 AM
BassProCamaro97's Avatar
Go with strange DA if you have the money to buy them. Otherwise, SA will be fine. I perfer having the extra adjustability in front. I have singles in back. There are some very fast cars running on SA shocks.
If you plan to stick to that weight then go with the 325lb.
~Jim~
