QA1 settings
Old Nov 3, 2009 | 04:34 PM
RPM Transmissions's Avatar
Default QA1 settings
I'm looking for some suggestions on starting points for my sons camaro. The car is a 430 rwhp 6 spd car with all of the rear suspension pieces (spohn adj lowers,torque arm,drag sway bar,pan hard.....). It has QA1 single adjustable rears with factory springs and double adjustable on the front with 275 lb springs. The car is a full weight car with 295/50/17 et drag radials. I'm just looking for a good starting point on the shocks for drag racing at the track.
Old Nov 3, 2009 | 04:40 PM
getusum's Avatar
You are better putting this in the drag racing section....Probably get rid of the drag radials....It takes alot, I mean alot of work to hook a m-6 with drag radials..
Old Nov 4, 2009 | 11:41 AM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
If you want to give me a call here at the office i can help you with your setup. I am in the office until 6pm est mon-fri.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
