Lowering Question
Old Nov 25, 2009 | 06:02 PM
Birdmanlt1350's Avatar
Default Lowering Question
Im thinkin about lowering just the front end, maybe to give it a more aggressive look and improve the handling a bit. has anyone ever done this? if so what problems have you run into? would you still need a panhard bar or adjustable torque arm?
thanks.
Old Nov 26, 2009 | 06:53 PM
thelast93's Avatar
Shouldnt cause any probs. The air dam might scrape a bit with the tail up in the air. No need for different parts in the rear. You might want to replace the upper ball joints in the front while you have it apart. (lowering is hard on the upper balljoints)
Old Nov 26, 2009 | 08:57 PM
cool man thanks!
