brakes locking up
If the above is the case, you are losing vacuum in the brake booster, and therefore losing you power brakes. This can also happen if you jump on the brakes quickly after being WOT because you don't have engine vacuum @ WOT, and the immediate jump to the brakes doesn't give the booster time to store vacuum you do get when the revs drop.
I'd say you have a bad booster that leaks vacuum, or a bad vacuum line leading to the booster.
say im in traffic, i start to brake, stop, start to break again...thats more what i meant
