Please help me diagnose this problem.
You could have a broken shock mount, the mount itself it not tightened snugly against the shock (doubt this is it would have been noisy from the start). The bolts holding the shock (and upper a-arm) into the car could be loose. Could be loose rod-ends on the control arms (but now hearing it I'd say that's not as likely as I thought before). You need to get the car in the air, and start moving things and find it... could be a number of things.
I'd recommend you jack the car up some, use a pry-bar under the tire and move it up and down and see if you chase down the noise better.
I've never heard a shock make that noise unless is was hugely broken. The problem is I can't see the car, and when you push the body down lots of things move. The shock, spring, a-arms, and anything that's not connected as it should be can also start to move and make noises like that.
