Cutting Springs????
I usually cut 1-1.5 coils off depending on the desired ride height people want. 1 coil off is going to lower the car roughly ~.75-1 inch. 1.5 coils will lower anywhere from ~1-1.5 all the way around. I wouldn't recommend cutting more than 1.5 coils, I cut two off one guys car and that thing was almost sitting on the tire, to low.
Just make sure to use a tool that has fairly high rpm, and a good cutting disk. You don't want the spring getting to hot, so a quickest cut as possible is good. Shoot me a PM if you have any more questions....
Josh
Start with 1 coil all the way around, the back is the easier, but the fronts will need to be cut before seeing the difference..Good luck
josh
Your car looks good Trick Dizzle....
