Front end feels light after alignment
Old Jan 28, 2010 | 06:54 PM
sneaky7980's Avatar
Default Front end feels light after alignment
Took the T/A in for an alignment because it had been tracking really bad on grooved roads and was told that i needed to change both outer tie rod ends and one inner. I went ahead and replaced everything with some MOOG parts and took it in for an alignment. It now pulls to the left a little and more importantly, at highway speeds the front feels very light and at 100-130 the steering wheel vibrates like a bent wheel. Let alone the front end steers like it's off the ground.
I'm going to get it realigned somewhere else but i just want to understand how an alignment could cause these problems, aside from pulling left, that is!
Old Jan 28, 2010 | 08:19 PM
SOMbitch's Avatar
When my car was stock it started feelin light in the 130 range. I would get a GOOD shop to check it out....
Old Jan 29, 2010 | 11:38 PM
nassty00's Avatar
mine feels the same way
Old Jan 30, 2010 | 12:32 AM
DriftR's Avatar
Negative caster will cause your car to "wander" and make it feel unstable at high speeds.
Old Jan 30, 2010 | 05:51 PM
Jeff 97 Formula's Avatar
Could also be due to excessive toe-in. My car recently had an alignment due to a slight drift to the left. My car drove straight after the alignment but felt light and numb compared to before. Had them bring some toe-out (to just above 0), and it drives nice and tight again.
