Sub frame connectors
Old Feb 5, 2010 | 06:57 PM
Gutz's Avatar
Default Sub frame connectors
I have a quick question.I bought umi's bolt-in subframe connectors and am installing them right now.The directions say to torque the rear bolt going into rear control arms to 72 ft lbs. What about the two in the front?Are they also 72 ft lbs?
Old Feb 5, 2010 | 08:01 PM
SS101's Avatar
if you have an impact wrench just zip them on as hard as it will go
Old Feb 5, 2010 | 09:15 PM
twelver12's Avatar
i would think that they would give you a spec for those too in the pamphlet you get with the sfc's, if not use the same number or just do the impact like said above
Old Feb 5, 2010 | 11:56 PM
Gutz's Avatar
The instructions weren't clear so i torqued everything to 72.
Old Feb 6, 2010 | 12:00 AM
The Manalishi's Avatar
Check the front ones after you drive it for a while. You want those tight and you want them to stay that way.
