Power steering issue
Old Feb 8, 2010 | 04:58 PM
The SSheriff's Avatar
Default Power steering issue
Hello everyone,
Just installed a Turn One power steering pulley, pump, and reservoir and all of them work great. I also installed a new high pressure line (NAPA) and it seems to work fine as well. However my power steering fluid keeps leaking out, both with the car on and off (more with the car on).
Where the hell could it be leaking from? I don't want to burn out yet ANOTHER power steering pump.
Old Feb 8, 2010 | 06:53 PM
RA032926's Avatar
it could be leaking from all the aforementioned parts or the rack itself... clean everything off and see if you can spot the area it's coming from... double check all the fittings/hoses and make sure they are tight and you did install new o-rings i'm assuming??
Old Feb 8, 2010 | 07:12 PM
Nemesis350's Avatar
Maybe the return line (non pressured) could be the culprit. But if everything on top look dry on top, more than likely your rack is leaking
