sa QA1's
Old Feb 14, 2010 | 02:15 AM
SICKSS/Z28's Avatar
Default sa QA1's
what setting do i put my rear single adjustables on?
Old Feb 15, 2010 | 07:37 AM
UMI Sales's Avatar
Hello
When you go with a adjustable shock its a trial and error process. Everyone's suspension is different and you have to see what setting works best with your set up. If you have any other questions feel free to ask!
Thanks
Brad
Old Feb 15, 2010 | 03:05 PM
BMR Tech's Avatar
Good rule of thumb is to start in the middle and go from there.
At the track you want to run the shocks adjusted as firm as possible and still hook.
For example on a really well prepped track you might be able to run a much firmer setting then a real slick or poorly prepped track surface where you would soften the setting to help the car gain traction.
Any questions please ask
Old Feb 16, 2010 | 05:55 PM
99Bluz28's Avatar
On the street you'll want them set anywhere from full soft, to 2 clicks.
Old Feb 20, 2010 | 08:02 PM
SICKSS/Z28's Avatar
thanks guys
Old Feb 20, 2010 | 09:48 PM
DrkPhx's Avatar
What? Have you tried to actually drive on the street with settings that soft? lol
I set mine to either 6-7 on the rear and 5-6 on the front depending if I use my 18" street tires or race setup. Track is completely different. Like mentioned above it comes down to trial and error depending on your preferences.
Old Feb 21, 2010 | 08:35 AM
99Bluz28's Avatar
Yes, on the street you'll want the QA1 SA rear shocks set low, unless you have really smooth roads, or don't mind the bounce.
Been there, done that.
