What should I do next?
Old Mar 1, 2010 | 08:19 PM
mean_greenZ's Avatar
Question What should I do next?
well so far suspension wise i have installed UMI adj. phb., non-adj. lca's, and sfc's. Edelbrock STB. all made a BIG difference!! what should i shoot for next??
Old Mar 1, 2010 | 08:53 PM
therealcreeper's Avatar
shocks or swaybars
Old Mar 1, 2010 | 09:00 PM
99FormulaM6r's Avatar
100000000000+ threads on this already, lol. Shocks or sways as mentioned.
Old Mar 1, 2010 | 09:04 PM
bobbyd's Avatar
konis and stranos
Old Mar 1, 2010 | 09:13 PM
well this will make it 1000000000001 lol! are sway bars worth while or should i look more into a torque arm? also should the torque arm be tunnel mounted or trans mounted?
Old Mar 1, 2010 | 09:33 PM
lol, no problem. What do you do with your car? Corner carving? Strip? DD? It will help to know these things!
Old Mar 1, 2010 | 10:16 PM
it is my DD and i have been to the strip once. i would like to go more this season but it wouldn't be but maybe a handful of times.
Old Mar 1, 2010 | 10:19 PM
For a DD, I would say shocks first. Sways next, then a TA. For a TA, I'd say the tranny mounted adjustable ones, then get a relocation mount to take the load off your tranny.
Old Mar 1, 2010 | 10:20 PM
if they weren't worth it, I wouldn't have recommended them. do you have any traction issues? regardless, for a car that very rarely sees the track, corner carving is a lot more fun for a daily driver.
Old Mar 1, 2010 | 10:27 PM
lol this is true. yea traction is a problem. so your saying sway bars would make a DD car more fun to drive?
also if i can only get one at a time would the front or rear be more beneficial?
Old Mar 1, 2010 | 10:30 PM
Front would be more beneficial I would say for the first sway, but you need a balanced set to get the most out of them. Strano has 35/22's, and that seems to be a really good combination, as are 35/21's.
Sway bars drastically cut down on body roll, definitely a good idea. But, once again, don't forget shocks!!!!
Old Mar 1, 2010 | 10:43 PM
i was looking at the 35/22 from UMI. http://www.summitracing.com/parts/UPI-211213-B/
this is the TA i was looking at.. http://www.summitracing.com/parts/UPI-2203-B/
Old Mar 1, 2010 | 10:46 PM
Good bars, but the advantage the strano bars have are weight. Strano uses hollow bars, which usually saves 20 lbs. over aftermarket solid bars.
Old Mar 1, 2010 | 10:49 PM
ah i see.. what about the TA i picked out?
Old Mar 1, 2010 | 11:05 PM
Ummm....I believe the tunnel mounted TA's are the shorter arms, which I've heard isn't a great idea for a daily driver. These hurt handling and braking, and can actually be a cause for quarter panel dimples on heavy braking.
I'd go full length transmission mounted adjustable TA and get a new bracket. UMI makes good stuff tho!
Old Mar 1, 2010 | 11:08 PM
ok i'll look into that and the sway bars. thanks for the help!!
Old Mar 1, 2010 | 11:17 PM
No problem. Talk to either of the UMI guy's for more help, or Sam Strano if you plan on buying from him, he's VERY good with suspension.
Old Mar 2, 2010 | 07:00 AM
UMI Sales's Avatar
Great to hear! Glad you are satisfied with the performance that UMI Performance has to offer! If anyone has any questions feel free to ask. And I will be more than glad to help.
Thanks
Brad
