9" and Adjustable Torque Arm
Old Mar 26, 2010 | 01:03 PM
sschoeffler's Avatar
Default 9" and Adjustable Torque Arm
Ok so I had a 9" fabbed for me and the torque arm has to be cut down 3 3/4" because its too long to bolt to the side of the tranny. The guy that fabbed it and the torque arm mount said if he cuts more off the mount that it would make the mount quite a bit weaker. So now I'm needing an adjustable torque arm and I am really liking the setup BMR has with the torque arm tying into the subframe connectors. My question is will it work with having to be 3 3/4 inches shorter than stock? Will I have to cut some meat off of the BMR torque arm too or will the adjustments compensate for being 3 3/4 inches shorter?
Old Mar 26, 2010 | 01:11 PM
kierstyn's Avatar
I am thinking from what you are saying you may have to have a custom t/a made. I dont think a off the shelf one will work for you.
Old Mar 26, 2010 | 01:20 PM
I wonder if someone would have a broken one that I could buy as a starting point and work from that. Also for BMR and UMI to come in here and let me know if their stuff will work or not. I called BMR the other day and they said they cannot make one to be 3 3/4" shorter. They also said they didnt know if it could be adjusted to compensate for it.
Old Mar 28, 2010 | 05:12 PM
kierstyn's Avatar
How about trying a long arm setup with relocation bracket?
Old Mar 30, 2010 | 07:59 AM
because the long arm style bolts to a piece of thin sheet metal. I want something that is bolted/welded to the subframe.
