ABS, braking question?
Old Apr 1, 2010 | 08:27 PM
robsquikz28's Avatar
Default ABS, braking question?
I have a 3 channel abs vehicle that im now installing a 4 channel rearend into and do not plan on using abs. As you can tell the abs sensors are no longer their. Can I just drive the car the way it is and have the abs edited out or what? Or will I have to install a abs delete kit? I would like to figure this out soon, while everything is still fairly easy to get to and I have the time to work on it.
thanks
Old Apr 2, 2010 | 12:53 AM
bigj2717's Avatar
You can leave the abs in there if you want it just wont function. There is no way to have it tuned out because it is in the BCM on the PCM the abs light will be on no matter what. I would just get the abs delete to help clean up the engine bay and save some weight since it wont be working
