grease fitting problem on umi phb??
Thanks for choosing UMI Performance for your suspension needs. It is a possibility that the roto joint might be over tightened. And when that happens the delrin is too close. Did you happen to disassemble the product by chance? Because each roto joint is tested and pre greased before shipping out. If you got our roto wrench part (0019) then just loosen the roto joint up a quarter turn. If you have any other questions feel free to ask or even call and I will be more than glad to help.
Thanks
Brad
Thanks for getting back to me! Unfortunately there is no way to loosen the main cap without messing it up. Feel free to give me a call and I will look into it and see what I can do for you. I will be in the office M-F 8-4:30 EST.
Thanks
Brad
Hope that helps,
Ryan
I would suggest to just tighten the end up until it is flush and make sure you have some Blue loctite on the threads. If you have any other questions feel free to give me a call and I will be more than glad to help.
Thanks
Brad
What the problem is sometimes is seeing how the roto joints are pre greased. The delrin can be tight. Just run them for awhile and wear them in. And then pump 1-1.5 pumps in each fitting. If you have any other questions feel free to ask.
Thanks
Brad
What Brad was trying to say is- The Roto-Joint is a tight tolerance item and is under pressure. We pre-grease them when assembled but once the item wears some and the grease breaks down it will take grease.. it is just tight and full right now. Run them for a few thousand miles and try it again.
When you say (Sides) are you talking about at the end of the bushings? Or the side or the grease fitting? If the grease is coming from the bushing then there is too much grease in the bushing and it will blow out and get ruined. But if the grease is coming out of the sides of the fitting just tighten it. If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
Hope that helps!
Ryan
