Help with squeak that goes away when ebrake is pulled
Can someone tell me what I can do to fix this?
so anyhow I cant tell if its my driver side or passenger side that is squeaking but I started by setting the e-brake only on one clicks and tried to rotate the rotor...then I moved up to two, three, etc. I noticed that only after like 4-5 clicks I cannot rotate the passenger side but on the driver side I can still freely move the rotor. So does this mean that the passenger side is to tight or that the driver side is to loose when it comes to what is making the squeak?
