Something Strange Going on.. with noises
So installed a bunch of suspension stuff a few months ago, BMR Springs, Koni's, Spohn Upper and lower arms, UMI Sway up front and bolt on SFCs, all has been fine.
Over the last couple of days something is popping over bumps and making a lot of noise esp when backing up. And in reverse it also most seems like the car is "skipping" or "slipping" esp when turning at the same time. Almost like something is loose. This is all coming from the front end...
Took the wheels off and checked all the bolts, etcs but everything is tight.
Anyone have any ideas?
Thanks!!!
