Adjusting ride height
Thanks
Just jack the car up one side at a time, pull the wheel off, place a jack stand under the car, then adjust the spring seat; repeat on other side.
Just do what I stated above.
Jack the car up one side at a time, pull the wheel off, place a jack stand under the car, then adjust the spring seat*; repeat on other side.
* First loosen the jam-nut under the spring seat, then spray some dry lube around the spring seat where the coil contacts it, and spray some on the threads on the shock body directly above the spring seat. That should decrease the effort required to adjust/turn the spring seat up higher. Also if you know(in inches)how much higher you want the front of your car to sit, then adjust your QA1 spring seat up 1/2 that amount. That should get you really close to where you want it.
