brakes grinding?
I took all the pads off, repositioned the pad backings to where they were supposed to be (which was not really optimal since they were now slightly bent up), greased them and now no more noise.
I don't know if its the same problem, but it might be depending on if you greased the back of the pads or not.
I have brembo blank rotors in front and power stop blanks in back, and power stop Z26 pads all around. I only say this in case you have the same pads and it's something common with these particular pads.
what could be causing this? My car is all fixed now and I started seeing cuts in my rotor, so I changed my brakes I lined up the lines to the clip(mounting things) and that was it. I thought it was just me but when I put my new ads and dimpled/sloted rotors it sound like a damn weed wacker!
