Torque Arm Bracket
Old May 24, 2010 | 06:41 PM
02 BLK WS6's Avatar
Default Torque Arm Bracket
Here is a pick of the brackets that come with the Spohn Tq Arm with a drawing next to it to give and idea of the size you'll need so you can adjust Instant Center. You will run into issues with driveshaft clearance. I cut the nut thickness in half and cut the bolt to be flush with the end of the nut. This is a Poly/Poly mount. If you were to change over to rod ends, the clearance issue should disappear without modifying the nut and bolt (something I plan on doing eventually).
Old May 25, 2010 | 07:16 AM
UMI Sales's Avatar
Hello
I just wanted to leave you know that UMI Performance offers a bracket that offers 2 settings for instant center change. That drawing that you show would be nice but you might have clearance issues with the longer brackets and the tunnel area. Below is a link to show you what I am talking about.
http://www.umiperformance.com/catalo...0vdsotjq79ok03
If you have any other questions feel free to ask.
Thanks
Brad
