Point of panhard bar relocation?
Thanks,
Matt
I'm not lowered, but it is about a 10% possibillity in the future.
I might go without it for a while then and use the cash for other parts. I have the TSP true duals on the way, but might just leave them dumped for a while. I'd just hate to spend the extra cash for the relocate just for my exhaust and no performance.
I was hoping to hear that it has a slight performance advantage...
To make one truly effective for modifying roll center you would need to be able to adjust the mounting height on both end of the bar.
The ideal position would be for the bar to be perfectly level at ride height.
Anything less than level would be less than ideal (obviously) If the car is lowered you will run a strong possibility of the relocation mount being lower than the rear mount.
The only way to correct this would be as mentioned to use a bracket to lower the axle side of the bar also.
