Best Sub-Frame Connectors?
Oh and bolt-on? or weld-on?
Thanks
P.S. What is the best suspension upgrade for our cars? Would it be the sub-frame connectors? control arms? sway bars? torque arm? or panhard bar?
Tommy
I called BMR regarding how the front tabs were both too far outboard of the front subframe- they tried to blame it on my car having a bent frame (interesting because it was exactly 3/4" outboard, both drivers & passengers side). So, knowing my car was never in an accident, and never abused before- I took it to a body shop anyway- because I was worried. A laser straightness test says- frame is straight- the SFC's were wrong. I'm guessing it was a "1 time mistake"- since many have had luck with them. But either way- I feel the Spohn units are superior product, from a superior company.
I don't have any experience with anything other than BMR & Spohn though.
Al
eric makes some, and is a very informative guy. they are priced well too. i am about to order some myself. that's about all i can tell you right now
i'll give you more information when i get them
I am real happy with them. When I first had them installed, I didn't think I felt a difference. However, when I jumped into my other vehicle (Mustang) with no SFCs, I seriously thought something was wrong with that car's chasis. It felt real loose. I had NEVER felt that difference before, and as a matter of fact, I always felt that the Mustang was a better built vehicle, as far as the chasis and interior was concerned.
The SFC's definitely stiffened up the car and made it more pleasurable to drive. Now, I am in the process of saving up for some SFC's for the Stang!
If I had to buy SFC's now I would get the Global West tubular sub frame connectors since they are stronger and have better tabs to weld to. They use 2" diameter roll cage tubing and the pads to weld to are much larger and make better contact with both the tubing and frame.
Here's a good site that shows how to properly install weld-in global west sfc's that I found. Install toward the bottom of the page.
http://www.authorized-amsoil-dealer-...humbnails.html
