knocking sound from rear
Old Jul 4, 2010 | 07:42 AM
Nebu's Avatar
Default knocking sound from rear
hello,
my car is making a knocking sound and i think it's coming from the rear. it sounds like shaking one dice in the dice cup. sometimes it's faster and sometimes slow. it only happens when i let the car decelerate from ~35 mph in overdrive or d. when i give a little bit gas or shift manually in second/first there is no knocking.
any ideas?
thanks,
nebu
Old Jul 5, 2010 | 12:58 PM
BBYZED's Avatar
I had something like that a couple years ago. At low speeds when coasting I could hear an almost swishing sound, not as much of a hard knock, but a softer sound. Turned out my diff was shot.
Old Jul 5, 2010 | 02:02 PM
battousai's Avatar
check the wheel studs, that kinda sounds like what happened to me, and the studs broke.
Old Jul 5, 2010 | 09:33 PM
Starion's Avatar
This is the classic torsen differential "marbles in a can" sound. Either live with it, or you can try to shim the retaining pin a bit to cut down on the rattling. When the differential is not under load the paddle piece rattles around making noise. It's just the design and there's nothing wrong with it. I think some are just noisier than others.
Old Jul 5, 2010 | 11:16 PM
SSHAWK's Avatar
I had the same thing happen to me about 5 years ago and it was my gears getting ready to go out.
Old Jul 6, 2010 | 10:55 AM
Nebu's Avatar
thank you guys. so i think i'll just live with this torson sound until it breaks apart...
nebu.
