Torque arm insulation?
I hope that makes sense, I'm basically trying to reverse the torque arm directly transferring gear noise to the body and thus making it extremely loud. I keep seeing on factory exhaust attend at work where there is a mount for a large rubber cylinder. I'm assuming that is there to absorb any harmonics that are created?
Would something like that work? Or any other suggestions?
The idea is to wrap the around parts of the TQ and see if it will dampen some of the vibs and find a tool that show the amount of vibration being generated and see if it works.
Like mentioned above what you could do is cut 2 little pieces of rubber and place under the cross member itself for a insulator. But seeing how the bushings are poly and a much firmer material over a rubber they will transfer gear noise. Unfortunately we don't offer rubber replacement bushings either. Sorry for any inconvenience, If you have any other questions feel free to ask.
Thanks
Brad
As a side note, part of my job is testing products for resonance points and nodes. I know it's not really feasible to expect anyone to be able to test a torque arm for natural resonance frequencies and do a modal analysis, but it's possible to take a thick, lower-durometer (i.e. soft) chunk of rubber and mount it at different places on the torque arm (using something like a big worm clamp or some zip-ties) to try and absorb some of that resonance. Might take some playing around with location, but it would be another thing to try. Unfortunately, different temperatures and rpms are going to change the modal response, so one spot may only work for a specific rpm range. I wouldn't expect a whole lot of harmonic damping with that setup, either...you may cut a little of the noise off, but don't be disappointed if it doesn't help much.
A shot-in-the-dark suggestion would be to try and put some damping material in the middle of the span of the torque arm, and adjust it back towards the axle in steps and see what location helps the most. You could try some very-high durometer neoprene padding, as thin as possible (probably 1/16" to 3/32") and put that between the torque arm mounting plates and the diff, which would cut some of the higher-frequency transmitted noise out. The key there would be to run the softest, thickest pad possible without affecting performance by introducing a lot of squish at the torque arm/diff mounting point. I'd personally think that would be more effective than a damper mounted on the torque arm length itself, since you'd be limiting transmitted noise at the source rather than trying to dampen out vibrations along the length of the torque arm. You could also try the same type of high-durometer, thin neoprene strips between the crossmember the torque arm mounts to, and the body.
As long as the neoprene is very high-durometer and thin, I don't think it would introduce any notable deflection between the diff and torque arm, as long as everything was tightened down properly, assuming there's enough space between the plates and the diff to squeeze it in. It'd probably be easier to get a big lump of rubber and play with clamping it around the torque arm, though, and that might reduce harmonics enough to make you happy without even needing to play with the diff mounting.
