TA Adjustment question
You do need to adjust the pinion angle while it is on the ground so you can set your preload on the rear. But I would suggest using four ramps, blocks anything that will be safe to allow you to get underneath and allow you to adjust your pinion angle. If you have any other questions about setting your pinion angle feel free to give me a call and I will be more than glad to talk you through the procedures
Thanks
Brad
http://www.bmrtvonline.com/video/3788
