New Double Adjustable SHocks
I read this and will be trying it for adjustment:
The extension setting on the front shocks is really important. This adjusts how fast your weight transfers from front to rear. Start with a middle setting and loosen 2 clicks each run. Watch your 60 foot times. Keep loosening the settings until your 60 foot times stabilize or you run out of adjustment.
The compression setting on your rear shocks is also important. Start in the middle and stiffen the setting by 2 clicks per run. Keep stiffening as long as your 60 foot times keep improving. Be careful. If the shocks are too stiff, the car will dance around on the top half of the track and you run the risk of losing control of the car. Not good.
