car wandering over bumps
Old Aug 5, 2010 | 10:37 AM
Asian LSX's Avatar
Default car wandering over bumps
Car is starting to wander over bumps and feels somewhat unstable above 70mph. I'll be fighting the steering wheel to keep the car from turning on its own, especially over bumps. In town the has no issues except for bumps. Theres slight play in the steering wheel but its overall tight like my SS was. Just curous what you guys think so I can plan on getting the money to fix it.
Old Aug 5, 2010 | 11:27 AM
Sam Strano's Avatar
LS1TECH Sponsor
I don't see anything mentioning better shocks than stock, and your complaint covers the two biggest issues of poor damping. A lack of stability and the car moving around a lot over bumps.
So, as I often find myself doing, I have to recommend some better dampers first and foremost.
__________________
Old Aug 5, 2010 | 02:15 PM
leadfoot4's Avatar
How many miles on the car? The tie rods and/or ball joints could be getting a little tired....
Old Aug 5, 2010 | 02:25 PM
tdevil55's Avatar
I have 115k on mine, and it started doign that as well. I started with wheel balance and that didnt help, then looked at alinement and tie rods, once I got the new tie rods and alignment, the play was gone, and less pull now. One issue that will not go away is the pull over bumps and ruts in the road, but that is being cause by the wide tires most of us run on these. To help that, work with the PSI on the front tires until you find a good range that you like the best for your driving.
Old Aug 5, 2010 | 03:04 PM
Asian LSX's Avatar
Car has 77600 on it. I'll have to look into the tie rods and alignment.
Old Aug 5, 2010 | 06:04 PM
libertyforall1776's Avatar
Old Aug 6, 2010 | 08:15 AM
wssix99's Avatar
Save the manuals!
You still have your stock shocks, right? Replace those and you'll have a totally different car.
Old Aug 6, 2010 | 10:08 AM
pjb's Avatar
pjb
agreed, but should have said replace them with GOOD shocks. cheap replacements may not help much.
Old Aug 6, 2010 | 11:12 AM
leadfoot4's Avatar
True, however if the tie rods, ball joints, control arm bushings, or sway bar bushings are worn out, he'll then have a nice riding car that wanders all over the place...
Old Aug 6, 2010 | 12:09 PM
wssix99's Avatar
Save the manuals!
Do you think that's likely after 75K miles?
Old Aug 6, 2010 | 05:40 PM
leadfoot4's Avatar
I would say that it's within the realm of possibility, without knowing the condition of the roads that the car has been driven on, bumps, potholes, a lot of wet weather to "wash out" the grease, etc... At 75,000 miles I'd be looking at the front end wear parts very carefully.
I also realize that I have the tools and experience to replace those parts myself, so it's cheaper for me to replace these parts than somebody that has to pay somebody to do it for them. Therefore I sometimes recommend replacement too quickly, but you also have to keep in mind that these are the components that keep your car under control. Break a b/j or tie rod while at speed, and you've got issues on your hands, in short order.
Old Aug 6, 2010 | 07:48 PM
BobDoLe's Avatar
i'd say before throwing down a gazillion dollars on random ****, you should jack up the front end of the car (using jack stands), grab the tires and check for excessive movement. like for outer tie rods, (hold 9/3 oclock position to check tie rods) if you notice a lot of movement around the outer tie rod area, replace those for like $40 each yourself.
Old Aug 9, 2010 | 09:34 PM
Asian LSX's Avatar
Thanks for input. If all I'm looking at is normal wear and tear items thats ok. I wish I had the coin for some Koni 4/4s.
Also, I did notice my front swaybar is gone as the previous owner took it off. Will not having the front swaybar have that much effect or is it possibly a number of possible things contributing?
Old Aug 9, 2010 | 09:59 PM
dlross's Avatar
i was going to say check the sway bar bushings and end links. but if they are not there then could be the problem. but still "shake down" the front end. if it has play side to side on the tire have someone lay under to find out if its inner or outer tie rod ends. outer rods only take about 10mins each side to change. hope this helps.
Old Aug 16, 2010 | 08:01 AM
Dmitriy's Avatar
I had the same issues with wandering on the freeway, was really scary having to snap the steering wheel 15* to counter steer bumps/ruts on the freeway, was more of an issue on the freeway. I went through my suspension links and all was nice and tight.
I gave up troubleshooting the wandering and figured it was just a f-body chassis issue. The wandering did not go away until I put new shocks - which were Koni's, I was doubtful the shocks would help out with the wandering so much, but they sure did.
If Koni's are out of the question, the AGX adjustable's or re-valved Bilsteins Sam sells are right on the money from what I've read.
My steering wander did not go away until the Koni's went on, because my stock struts were completely shot - I tested them after taking them off and they would not de-complress at all
Koni's were a very expensive option for my budget, took me a while to save up for them, and will take me even longer to get a proper working strut from them (adjuster issues different topic)... You pay a big price for Koni's performance, this does NOT mean you will get your money's worth in service or quality control... but that is another different topic...
Last edited by Dmitriy; Aug 16, 2010 at 08:05 AM. Reason: cause i cant fucking spell or structure my sentences to save a drowning child; fuck it
Old Aug 16, 2010 | 08:50 AM
BMR Tech's Avatar
No front swaybar along with possible bad shocks and worn tie rod ends would certainly have some off handling characteristics.
Check the parts forum it's possible to find either a good used aftermarket or stock front swaybar that would certainly help your situation.
I would also agree with checking rod ends and just alignment in general can cause wandering issues.
Old Aug 16, 2010 | 11:18 PM
ZTwentyAteU's Avatar
I'd check on shocks, check the tie rods
and if its ever been apart, like the k member out, check the bolt on the rag joint at the rack, I've had a car that that someone didnt tighten that on good enough and ther steering had play
Old Aug 18, 2010 | 12:19 AM
Asian LSX's Avatar
Thanks for well detailed input guys.
Old Aug 26, 2010 | 02:29 PM
superduce's Avatar
Same issue. I just had alignment and even changed the complete rack. Tie rods are fine. Only 35k on my 93. Pulls side to side. Original struts. Car is like new but I can't stand driving it.
