Braking problem
Old Sep 15, 2010 | 09:41 PM
turboelky's Avatar
Default Braking problem
I am putting this out there hoping one of you has experienced this problem and tell me the fix. My Camaro has a ford 9" with Aerospace Componet Billet brakes, no ABS. My front brakes consists of Aerospace Componet Billet brakes with no ABS either. I still have the ABS motor under the hood with all the lines attached, I am lazy and did not perform the ABS delete yet, I also have an SLP line lock installed. For 2 years this system performed flawlessly, but a couple of months ago i started having an unusual problem. The brake pedal drops under accelleration and only under accellearation, if you are at idle you have perfect brakes, but when I try to stall convertor, the pedal drops to the floor and the car rolls the beams. If I had not installed the linelock, it would not even do a burnout. So far I have changed master cylinder, rotors, brake pads, conventional brake bleeding, and last but not least, Snap On scanner bleeding the ABS. I still have the same problem. Please if you have any thoughts on this, or have also had this problem, I could use your help.
Old Sep 16, 2010 | 02:29 PM
turboelky's Avatar
So, none of you have experienced this problem before.
Old Sep 16, 2010 | 02:40 PM
Element's Avatar
Not really sure, but potentially a brake booster issue?
