stainless brake lines
Having no idea where they came from, I'd call who you bought them from and have them fix it. I sell Techna-fit, if it was me who screwed up, I'll own it... mistakes happen and I'd make it right. If it's someone else, it's up to them to fix it.
traction control cars have 2 brake lines going to the rear end as opposed to one, there's 2 flexible lines connecting the brake lines mounted to the chasis to the rear end. On non traction control it's a single line going to the rear end, then the T is on the rear end allowing the hard line to split to each wheel.
you got the kit with 2 lines, should have 6 total, one for each caliper = 4 plus the 2 connecting the rear axle. You'll have an extra one.
When I bought mine years ago, the kits typically came with only 4 or 5 lines, finding the kit that had that extra line for traction control cars was a pain. Many times the kits only came with 4 and you never touched the rubber flexible lines connecting the rear. Unless you paid a lot more for the traction control (extra line) kit I wouldn't worry about it.
