alignment for new suspension
Old Dec 25, 2010 | 03:10 AM
greasess's Avatar
Default alignment for new suspension
This weekend I'm installing a bunch of new suspension. The list includes #### BMR hiem/poly LCAs, BMR hiem/poly panhard, 1 inch drop 170lb rear springs, QA1 rear single adjustable shocks, BMR k-member, BMR poly upper A arms, BMR lower A arms, QA1 single adjustable struts, 325lb .5 inch drop springs, BMR sway####. What kind of alignment would be best for my setup keeping in mind that I want to handle? I was thinking -2 degrees camber, .5 degrees toe out and maybe -2 pinion angle. Any thoughts would be appreciated.
Old Dec 25, 2010 | 12:06 PM
JD_AMG's Avatar
Im sorry to be the bearer of bad news but you should have searched before you went and randomly bought parts. If you have any interest in handling then your best bet would be to ditch the drag shocks ASAP. Those are going to be holding you back a lot, and make the car unstable, unpredictable and nervous to drive while being floaty and jarring at the same time.
As far as alignments this is a good general idea here:
http://www.angelfire.com/my/fastcar/suspension.html
Old Dec 25, 2010 | 01:27 PM
lethal bird's Avatar
What he said if your going for handling your going to really want to get rid of the QA1s and get something like some Koni's.
Old Dec 26, 2010 | 12:44 AM
greasess's Avatar
Thanks for the link. As far as the shocks go, I chose them for a reason.
Old Dec 26, 2010 | 11:07 AM
JD_AMG's Avatar
Whats the reason?
Just don't expect to have good handling or ride quality with them, and check for leaks often too...
Old Dec 26, 2010 | 04:56 PM
greasess's Avatar
There isn't anything inherently wrong with a QA1 shock. I'm planning on modifying them. I'll change the valving and a few other things. I want 9 second passes and handling. I know that won't allow me to do as well as I could at either but that's ok. Besides! Wheelspin at 100 is fun What's your setup like?
