Torque arm help
Old Jan 4, 2011 | 01:58 PM
SSWHOOPIN's Avatar
Default Torque arm help
Ok guys I have a 00 SS Camaro I have a quick performance 9inch with the adjustable torque arm bracket. I have a spohn adjustable torque arm. The problem is the the rear bracket on the torque arm is hitting the floor of my car. I do have an adjustable pan hard bar as well. Wondering if I need to move the axle over to the right more so the torque arm bracket will clear the tunnel. Any Ideas????
Old Jan 4, 2011 | 04:06 PM
Pilsner's Avatar
Check the rear axle for center between the wheel wells, adjust so it's even with PHB. The rear axle will move to the right with compression.
Old Jan 4, 2011 | 04:10 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
9" ring gears are much larger diameter than the OE 7.5", forcing the torque arm mount over slightly. Couple that with a larger aftermarket torque arm bracket and you get floorpan clearance issues. This is typical of any brand torque arm especially when used with a 9". Don't offset the rear more to one side to compensate, this will just cause alignment, tracking, ride height, and other issues to deal with. Instead, center the rear end as best as possible using the adjustable PHR, then clearance the tunnel where the bracket hits. It's usually just a corner of the bracket and a large dead blow hammer can give sufficient clearance...
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
