K-members
Old Jan 7, 2011 | 01:37 PM
dphc18's Avatar
Default K-members
Why does BMR have motor mounts welded to k-member and PA has bolt on mounts?
I need to buy one or the other just wondering what experiences anyones had with either, I was thinking the bolt in one just makes for more possible loose bolts but it might be better for engine install?
Old Jan 7, 2011 | 03:30 PM
UMI Performance's Avatar
We also have our motor mounts attached to the K-member rather then bolted. The main reason we do it is for maximum weight savings, this helps eliminate unnecessary weight to the K-member, in our opinion at least.
I hope that helps,
Ryan
Old Jan 7, 2011 | 03:38 PM
dphc18's Avatar
Does UMI make a K-member for down pipe clearence? (Turbo K-memeber)
Old Jan 7, 2011 | 03:46 PM
BMR Tech's Avatar
Good talking to you on the phone.......
Let me know if you have any additional questions
