Install panhard bar
Old Jan 26, 2011 | 09:10 AM
00silverGTP's Avatar
Default Install panhard bar
anyone have write up for this? or how to adj it when its on? I am lowering the car at the same time.
Old Jan 26, 2011 | 09:22 AM
VinR1's Avatar
what brand and model is the bar? adj? double adj?
Old Jan 26, 2011 | 09:32 AM
99FormulaM6r's Avatar
http://www.installuniversity.com/ins...sity/index.htm
This is the installation for a non-adjustable, which is pretty similar except for the adjustment part
As mentioned above tho, is it an on or off car adjustable PHB?
If it's an on-car, try to get the new arm the same length as the old one before you put it in the car (adjusting it off the car is easier) and then maybe just a little bit shorter (to help pull the rear back to the correct position). After that you can measure wheel-fender distances and try to fine tune it.
Off car is similar, but it has to be removed to change the length.
Old Jan 26, 2011 | 09:41 AM
I bought this
http://www.bmrsuspension.com/index.c...&productid=295
do I need ramps or will stands and a jack be ok?
Old Jan 26, 2011 | 12:20 PM
Undertow74's Avatar
Ok, easy buisness. once you get all your spring and such done jack up the rear of your car under the differential, take out old panhard rod, adjust new one to the stock length, bolt new panhard up. Now you are going to want to adjust it with the *** in the air, otherwise have fun centering the rear with the tires on the ground.
Then get yourself a plum-bob and a measuring tape. measuring from the top of the fender well to the lip on the top of your rims(using the string on the plum bob), adjust until both sides are even(within 1/8th of one another). then tighten your jam nut on your bar make sure to put blue loctite on it.
Im pretty sure bmr has install pics on there website if you need a visual. its very simple
Old Jan 26, 2011 | 01:47 PM
cool thanks.
