Feels Like Something is LOOSE
Old Jan 26, 2011 | 04:35 PM
madmike9396's Avatar
Red face Feels Like Something is LOOSE
When i get on the throttle it feels like my rearend is trying to roll out from under the car ! What is the deal ? Bad Torque arm ? Worn bushings ? Broke LCA ? It is a 01 ta m6 with stock 10 bolt.
Almost got enough for my s60 but i want to make it last till i get it lol
Thanks to anyone with info
Old Jan 26, 2011 | 05:08 PM
JD_AMG's Avatar
Probably time to get under the car and tighten bolts and look for anything broken. But it does sound like either a torque arm or LCA issue.
Old Jan 26, 2011 | 05:32 PM
cool thanks that what i was figuring. gona jump on it soon as it quit raning
Old Jan 26, 2011 | 06:25 PM
meatyz's Avatar
does this only happen when under hard throttle? is it like a vibration in the rear of the car?
Old Jan 26, 2011 | 08:03 PM
just under hard throttle it feels like it twist and it feels like it is loose between the trans and rear because when i shift i can feel a bump under the bottom of the car like the trans mount is broken or they is alot of play in the drive shaft
Thanks guys
Old Jan 26, 2011 | 09:26 PM
99FormulaM6r's Avatar
Could your TA bushing be shot? Or maybe it's loose? It seems like a bump under the bottom of the car could be the TA hitting the body or something.
Old Jan 26, 2011 | 09:48 PM
JonCR96Z's Avatar
Does that car have aftermarket suspension on it?
Old Jan 26, 2011 | 10:49 PM
Raptor_WS6's Avatar
check your tq arm bolts, my come loose and it feels like banging on the floor board..
ima use lock tight on them
Old Jan 27, 2011 | 12:15 AM
sjsingle1's Avatar
check tranny mount too
Old Jan 27, 2011 | 03:43 AM
Turnin20s's Avatar
Could be a bunch of different things, your best option is to get under the car and look everything over.
Could be...
Tranny mount
Motor mounts
TA mount
loose TA
LCA bushings
PHB bushing
Bad U joint
blown shocks
low tire pressure
and how knows what else.
Old Jan 27, 2011 | 12:42 PM
Undertow74's Avatar
A bump under your floorboard could be your torque arm, but also could be your Y pipe slamming into the floorboard also.......... Definatly climb under there and check things, could be a number of things to include a busted TA
Old Jan 27, 2011 | 02:44 PM
ToxicWS6's Avatar
i had the same problem a couple of times lol, first time it was Y-pipe and TA, my engine and tranny mounts were ripped and shot, replaced them with poly mounts and it fixed it, later down the line i ended up gettin UMI LCA and adjustable torque arm and 1 1/4 sway bar, i still have a slight thump when hittin the gas in mid gear and if i hit a bump something bangs around a little, idk if its exhaust or what but id check ur mounts and bolts first
Old Jan 29, 2011 | 06:30 PM
its all stock suspension. Just havent had time to look since i been working 7 days
thanks guys
Old Feb 21, 2011 | 06:11 PM
turns out i went to put my new torque arm on and i could twist the bolts by hand lol
