powerslot rotors - rust problem?
Just wondering if anyone else with Powerslot rotors has experienced what I have.....
I put the rotors on the car in the summer of 2008. First two years no issues. This past summer (2010) I started getting a bad squeal when braking. Checked the pads, lots left on them. The rotors showed no signs of scoring either. I took it to the shop, mechanic found rust buildup on the inside of the rotor cap, along the edge, and the pads were rubbing that and squealing. They cleaned them off, squeal gone. Fast forward ~6 months to now, squeal is back. Is this common with Powerslots? The 2 sets of stock rotors never did this. Is it just because the car is winter driven?
Thx
Could just be accelerated due to the salt from the roads. Guess I'll clean it off when I take the winter tires off.
One thing you could do is use some hi-temp ceramic paint on the hubs.. If you push your car hard or attend HPDE events, the paint likely wont last, but if you just do some normal driving with the car, then the ceramic paint will likely last a long time and inhibit the rust issues. Just make sure you dont paint over the pad contact area.
