Lower Springs
You could do lowering A-arms (of course they use poly and a rod end, so that won't do much for ride quality or cabin noise), a set of 1" lowering springs, and the upper mount mod to gain some travel back. Bilstein shocks are a good choice. The rear, the hose mod is cheap and can get you .75" of a drop, or go with a set of lowering springs.
Read the stickies and get your self familiar with the options. You might also need an adjustable panhard bar. Depends on the width of your rear wheels.
Start here:
Suspension FAQ
Hose Mod
People will tell you not to, but I cut my springs and the car rides the same. No hitting bump stops, just scrapes the air dam, because I'm running a 24.5" front tire. I am going to get the MT front and a 325/50/15 for the rear and the fender gaps should be right where I want them. Do a search, it's your car, I don't like the rough ride of lowering springs, so I just cut them. Didn't cost a thing and if things didn't turn out the way I wanted I could always pick up used springs in the classified section.
Edit: And an alignment when you're done
