WoULD THIS BE A STRAIGHT REPLACEMENT DISK ROTOR?
Thanks in advance!
http://msperformanceonline.com/2301006.html
Do yourself a favor though and run a good pad with it.. You will not notice performance gains from new rotors, however you will notice a big improvement with good pads.
If you do get these.. I would seriously consider safety wiring the bolts on the hat.. You may need to get new bolts that have drilled heads or drill the heads on the bolts that come with it.
I like to play it extremely safe with 2 piece rotors only because the rotor separating from the hat is just about the most catastrophic thing that could happen.
I safety wired mine..
