when is it time to upgrade suspension?
Suspension wise.. not sure if anything breaks really. Except the torque arm mount on the tail shaft on the transmission
if you have the funds , upgrade everything you can , dont wait ..
Picture this: without subframe connectors, you go to the track, you launch, yell, "YEE HAA!!! WHEELS UP BABY! WOOO!!! SUCK THAT YOU HONDA WUSSIES!!!" and then click off a 10 second 1/4 mile. You go back to the pits and notice a small rumple in the rear quarter, then you notice your gas cover doesn't line up anymore, then you notice your car doesn't drive straight anymore, after a week you notice the tires are worn really bad on only one side! Then you'll realize that you just twisted the frame and the car is now useless junk.
Subframe connectors: shoulda been on the car from day one. thanks alot GM.
here kid, reading is fun-da-mental!
https://ls1tech.com/forums/new-ls1-o...anna-fast.html
read the part about half way down called, first mods
I suggest UMI. weld in. they're cheaper and definitely hold stronger to the car. trust me, you'll thank me in the end.
http://www.umiperformance.com/catalo...ex&cPath=7_113
if you want to try autocross, or like the pro touring look, go with the top ones, otherwise, go with the ones at the very bottom. ignore the square ones, they're outdated.
