subframe connector question, help!!!!
Old Feb 15, 2004 | 08:00 PM
VietRacingGuy's Avatar
Default subframe connector question, help!!!!
i just got tubular two point subframe connector.
does anyone know how to install this? any pictures will help!!!
and one more thing, one bar is longer than the other, like 3 to 4 inches. is it the way it is? because i thought they should be the same in lenght.
thanks
Old Feb 15, 2004 | 08:35 PM
Zo6Killer's Avatar
If you don't have access to a lift or some really high(truck/suv) jackstands this might not help, but...
-Looking from underneath, and having a helping pair of hands, you can lay them against the frame/floor and see how they SHOULD fit. Depending on brand, they may be a bit sloppy(if ya went cheapo) but shouldn't be too far off.
-If you've never done it before holding them up against the car on both sides will basically give you a road map of what's supposed to happen there. Bolt-in's will obviously have to line up with holes, where weld-ins can be left to a bit more "creativity" a 1/4 inch here or there.
Hope this helps.
Old Feb 15, 2004 | 09:46 PM
DARK AGE 53's Avatar
The lift needs to be the drive on type, here's some info off the BMR site. http://www.bmrfabrication.com/instructions/sfc001.htm
Al
Old Feb 16, 2004 | 07:22 PM
thanks
