Spherical rod end replacement
Old Mar 6, 2011 | 10:32 AM
Chesty for President's Avatar
Default Spherical rod end replacement
Ive had these on the car for a while and from the sounds of things i need to replace the spherical rod end on my panhard bar and my LCA's. I also have a Wolfe anti sway bar setup which im pretty sure helps out in the noisy/rattling part of this. My question is does anyone know the size of these rod ends or how can i measure them myself to buy new ones.
Thanks in advance for any advice or help
Old Mar 9, 2011 | 06:11 AM
UMI Performance's Avatar
They are most likely a 3/4-16 rod end but I have seen some companies use 5/8. Below is a link to replacement rod ends if this helps you at all.
http://www.umiperformance.com/catalo...x&cPath=13_217
I hope that helps,
Ryan
