alignment range with stock suspension
Old Feb 17, 2004 | 03:12 AM
kyle97's Avatar
Default alignment range with stock suspension
Most of the "performance" alignment specs I've seen listed (usually around -.07 camber, +4.5 caster, 0 toe) are given by people who have lowered suspensions.
I tried to get these settings on my stock WS6, but the mechanic could only get: -0.4 camber, +4.0 caster, 0 toe, saying that he had no more room for adjustment.
To get those performance settings, is a lowered suspension necessary? or is it possible to get those settings within the factory setup (and i just need to find a mechanic that knows the secret of how to do that)
Thanks!
Old Feb 17, 2004 | 06:33 AM
mitchntx's Avatar
That's about it for a stock sprung car.
However, that is a setting at neutral ride height. As the suspension compresses, you should get more negative camber.
Old Feb 17, 2004 | 09:31 AM
kyle97's Avatar
Are there any aftermarket A-arms that increase the range of camber/caster values you can achieve at the stock ride height?
Old Feb 17, 2004 | 03:27 PM
mitchntx's Avatar
I have LG Motorsports adjustable Lower A-Arms and Lou offers Uppers as well.
You can get a TON of negative camber and positive caster with these.
