Energy Suspension
Old Apr 2, 2011 | 08:23 PM
JBZ28's Avatar
Default Energy Suspension
Do any of you have Energy Suspension Hyperflex Bushing Kit? if so give some reviews
Old Apr 2, 2011 | 08:36 PM
Ghostintheshell's Avatar
Interested as well.
Old Apr 3, 2011 | 08:17 AM
leadfoot4's Avatar
Depends on how rough the roads are in your area, and how low a profile a tire you're running. Where I'm at, western NY, the roads are pretty rough, due to harsh winter frost heaves, etc.
I started using polyurethane bushings when they first became available, back in the late 70s. I started with control arm bushings and leaf spring bushings on my '77 Pontiac T/A. The improvement over the OE rubber bushings was an improvemment, but their slight increase in harshness wasn't all that noticible, due to the higher profile tires that were used back then. I continued using Energy Suspension parts until 1997.
In '97, I installed the full compliment of ES parts on my '96 Z-28. However, the combination of the roads, which are still trash around here, as well as lower profile, stiffer sidewalled, speed rated tires, made the ride way too bone jarring. The handling response was sharpened, no question, but I went back to the rubber bushings, to keep from destroying the car from the road impacts.
Old Apr 3, 2011 | 10:51 AM
bigj2717's Avatar
I put the whole kit on my car and I love it. The car feels a lot more solid
Old Apr 3, 2011 | 11:25 AM
JD_AMG's Avatar
If you are looking to improve handling/feel/response then fix the real problem first: the shitty factory shocks. Get some good sport shock on the car and then decide if you want more.
Old Apr 3, 2011 | 07:17 PM
JBZ28's Avatar
I was interested in changing the bushings because my stock ones are worn out. I will eventually up grade my shocks as well. I'm running a stock size tire (245/50zr16) so how much will they actually effect my ride quality?
Old Apr 4, 2011 | 05:18 PM
leadfoot4's Avatar
As I originally said, how rough are the roads where you live, and might travel to, if you use the car for a DD? The ES bushings DO give a stiffer ride...what are you willing to sacrifice?
Old Apr 4, 2011 | 06:26 PM
JBZ28's Avatar
I live in NY too so every road is pretty much crap after winter. The car Is my dd right now and I'm willing to sacrifice a bit of comfort if their is noticeable difference in handling
Old Apr 5, 2011 | 04:26 PM
lsx24's Avatar
Do not change the shocks without the bushings, your car will be fucked up.
Old Apr 5, 2011 | 05:11 PM
leadfoot4's Avatar
There IS a noticible difference in handling (positive), and there IS a noticible difference in ride quality (negative). You WILL notice it on NY's roads.
you've been warned.....
Old May 2, 2011 | 04:59 PM
dowienu's Avatar
re: energy suspension parts
or you could just buy a master bushing kit and have everything you need
Old May 2, 2011 | 05:07 PM
dowienu's Avatar
Old May 2, 2011 | 05:15 PM
dowienu's Avatar
Old May 2, 2011 | 05:22 PM
dowienu's Avatar
Old May 2, 2011 | 06:10 PM
amr84ss's Avatar
I am waiting to get my new front shocks, and at that time I will be putting on a front end bushing kit. I am sure it will help me out as I know that I have bad control arm bushings.
Old May 4, 2011 | 08:45 PM
Orange_LT1's Avatar
I bought and installed the Energy Suspension Complete poly kit and I have no complaints. I can't honestly tell you the true difference other then once my car was loose, now my car is tight... Wisconsin roads can get rough too, if I had to do it over again I would have replaced them when I first started driving it.
At the time I did the bushings I also did shocks, struts(& mounts), ball joints and tie rod ends.
Old May 4, 2011 | 08:53 PM
SVThuh's Avatar
You put struts on your car? Where did you put them? The fronts on a 4th gen are shocks.
If you do poly, at least do yourself a favor and get rubber replacement castor bushings. The poly's have a tendency to bind and break in that location.
Old May 4, 2011 | 09:52 PM
Orange_LT1's Avatar
Sorry I misspoke, Thanks for calling me out on it...
Old May 4, 2011 | 11:53 PM
sjsingle1's Avatar
polys.......mine is a DD........no problems after a yr
Old May 5, 2011 | 05:13 AM
SVThuh's Avatar
lol.. no worries.. Just a pet peeve of mine, like seeing someone say "Camero"..
