Need ABS Sensor Info
Old Apr 4, 2011 | 12:19 PM
currentman's Avatar
Default Need ABS Sensor Info
I picked up a 99 camaro for my son, and the RF abs sensor wiring was ripped out. I have connectors on my bench so I can make a new harness, but I need to know if the yellow wire is on the top or the bottom, this is for the passenger side front.
I search for a photo, but couldnt find any, thanks in advance.
Old Apr 5, 2011 | 12:05 AM
wrencher's Avatar
wrencher
I cant see the connector pinout here @ home.
But I'll tell you it's really not important which wire goes where.
Why the WSS is just a magnetic inductive sensor.
It produces A/C voltage. 2 wires no polarity to observe.
Old Apr 5, 2011 | 10:39 PM
currentman's Avatar
Thank you for the reply wrencher! ( I think I met you a few years back...maybe..)
anyway, I did know that about the way the sensor works, but sometimes I get lazy and hold out hope that its a simple fix despite all the things I forgot that I know....
well I ended up tracing it last night, and I found a short to ground about 3 feet into the harness, so I repaired it and now am receiving data from the sensor.
thanks again!
Old Apr 5, 2011 | 11:30 PM
wrencher's Avatar
wrencher
No problem I know the screen name I'm sure we've ran into each other @ us41/what ever they call it now raceway or 66, GLD etc lol.....
Old Apr 14, 2011 | 05:17 PM
derek3.4's Avatar
I have the same problem. Is the other wire blue-ish green-ish? Been wondering if those were the correct ones
