Should I switch?
Old Apr 5, 2011 | 09:58 AM
ssteven's Avatar
Default Should I switch?
I have eibach prokit for LT1's on my 2000 z28. I got the set up from stano along with the big 35mm front swaybar. Been driving on them for about 8000 miles. I also have KYB agx shocks. I was thinking about switching to the strano springs( at the time sam was out of stock) So will the stranos be a bit taller? I scrape once in awhile with my eibachs and I saw the spring rates willbe different between the two. Also I have NO plans on switching to koni shocks too much $$. My setup is great on the track but the real world its a rough ride.
Old Apr 5, 2011 | 10:53 AM
Sam Strano's Avatar
LS1TECH Sponsor
Taller? Pretty similar to your LT1 Pro-kit. But mine should ride slightly better as the springs rates are about 50 and 10 lbs/in. softer front and rear respectively, also that's just a little easier for the Bilstein's to control as well.
__________________
Old Apr 5, 2011 | 11:00 AM
ssteven's Avatar
thanks sam....you will be getting my order this weekend.
