2001 C5 vette, pic needed
Old Apr 7, 2011 | 05:13 PM
05HD's Avatar
Default 2001 C5 vette, pic needed
I inherited a project 'vette. Someone took the EBCM out and I can't sort out what line goes to what port trying to reassemble it. So, if someone could share a picture or diagram of what brake line attaches where on a front mounted C5 EBCM, I would be eternally grateful. Thanks.
Old Apr 7, 2011 | 05:16 PM
99FormulaM6r's Avatar
http://www.rjsmith.com/ECBM-replacement.html
That help?
Old Apr 7, 2011 | 08:44 PM
05HD's Avatar
Originally Posted by 99FormulaM6r
That help?
That is the stuff I am looking for, thank you. Anyone have a shot of the lines with the radiator hose out of the way?
Old Apr 8, 2011 | 07:34 AM
Brakemotive's Avatar
I'm not sure about the front mounted 00+ version, but the earlier rear mounted units had the brake line stamped above each port, lf, rf, lr etc.
Old Apr 10, 2011 | 12:41 PM
05HD's Avatar
No such luck with this one.
I'd be eternally grateful if someone could pull their radiator hose out of the way and snap a pic for me.
Old Apr 11, 2011 | 09:58 AM
Does that help any? The lines should kind of find their home...try to get one fitting started that you know is correct and the rest should sort of fall into place..
Old Apr 25, 2011 | 10:02 PM
05HD's Avatar
This got me to looking at all of the little writing on the unit. Lo and behold, it said "TOYOTA" on the ******* side!!! I have been trying to put a Supra ABS unit on the vette this whole time... The one that belongs there says Delphi on it and has all of the ports labeled as per what line goes where. It is amazing how close the Toyota and GM units are. The mounting bolt holes lined up perfect and everything.
