abs inop
Old Feb 20, 2004 | 06:46 PM
artic-z28's Avatar
Default abs inop
awhile ago one of my skinnys came off in the front .. loose lugs .... doh...
but it was my passanger side ... would that cause my abs inop to come on ... the abs sensor in the front get messed up ?
Old Feb 20, 2004 | 06:49 PM
Assassin's Avatar
check to see if it simply unplugged, I've seen that happen before
Old Feb 20, 2004 | 07:12 PM
ta12sec's Avatar
IF you have skinnines on the car the abs light will come on.
Old Feb 20, 2004 | 07:31 PM
EVIL's Avatar
only if the 2 tire diameters are different by enough for the pcm to think its seeing wheelspin.
Old Feb 20, 2004 | 07:37 PM
artic-z28's Avatar
i got the stock rim back on ... should i do a pcm reset ? i really think the sensor is messed up on the passanger side
Old Feb 20, 2004 | 07:43 PM
Fulton 1's Avatar
A PCM reset won't address an ABS issue. If the problem is corrected the ABS inop light should go off on its own and it should do so relatively quickly.
Old Feb 20, 2004 | 11:57 PM
demonspeed's Avatar
It's not mine! woo hoo!
You'll see the same on a dyno.
