Lowering with ground effects??
My concern is how low can I go before I start having clearance issues as far as jacking the car up, and driving in general....The car is not my dd and another concern is in one year it is going to be undergoing a forced induction and bottom end build when in the end I should be round 700rwhp and will be taken to the track oftenly...What springs are the way to go....
BMR is saying 1.25 inch drop...which Im concerned that its not that much
Eihbach is saying 1.5 front-1.3 rear which sounds better
Eihbach sportlines are saying 1.7 front-1.8 rear which I'm concerned is too low
Does anyone have any past useful experience, it would be greatly appreciated....
Also I installed rear kyb gas-a-just monotube shocks in Sept because one was blown, should I go the same with the front when I do the spring install??? Money was an issue at the time and will be until I start my job this summer, I'm graduating college in May
I'd say, if you already have a nice paying job lined up for summer, just get some BMR or Strano springs for now. Then, next year when you go FI, sell those springs and pick up some more drag oriented ones. Also, with putting 700 to the wheels, I hope you plan on quite a few more suspension mods as well.
Hope this helped,
-Brandon
Hope this helped,
-Brandon
Yes, you can. you just remove the spring isolator and put a rubber hose on the spring so there is still something there to prevent metal to metal contact.
